Sad Discovery: GM 10 Bolt Fails
Dleslie212
Phoenix
Dustin
5.7L 350
Thanks @Blue Ox and @Buck69 , I appreciate your thoughts on the matter. I have had three different friends give me three different pieces of advice so far. I would like this rear end to last a while Longer in the future and whatever work I do will hopefully help that possibility.
I don’t plan to wheel this truck super hard, but I do like the idea of added durability for whatever comes my way. As with everything else when he doesn’t grow on trees, and we have a pretty tight budget around the farm here at the moment.
FWIW, I completely rebuild my 12 bolt a few years back, only reused the housing itself. It took me a long long time. Probably a month, and at least 20 attempts of putting together and taking it back apart to try to get the backlash and preload right. It cost a bit of money as well, by the time all the parts and tools were purchased.
Where in AZ are you?
Buck69
Northern British Columbia
D30 CUCV
6.2 (removed)
That's why many of those trucks had a extra load sensing proportioning valve linked to the rear axle. They're not available anymore, but if you can't find a serviceable used one you could probably add a manual adjustable valve for when you're running unloaded.
Honestly don't remember it all. Don't believe that valve was in that truck and it was only a year and a half old when I grabbed it.
I do remember the shoes were larger in diameter but a fair bit narrower with the replacement axel. A lot more grab than it was meant to have leaving the factory.
Anyway, thrashing on these trucks as a young punk taught me lots with the wrenches. Miss them days and maybe has a bit to do with me getting back into them.
AZ Highlander
Prescott AZ
Frank
K15 (aka V1500)
350 (5.7L)
Prescott, AZ
the one reason ABS really helps in modern trucks is the ability to have DRP for the rear brakes!
3dbello
