Stuck Hood
projectmidnight74
Mississippi
Eddie
V8
So, my relic has returned home and is in the brightwork stages of repair. My only issue is the hood is now stuck closed after all the new parts have been added. Any idea how to get this thing open on a 74' There's no hood cable on this model for some reason.
CountKrunk
ATL
Count
C20 Custom Deluxe 3+3
v8 350
You're saying there's no hood release pull inside the cab?
projectmidnight74
Mississippi
Eddie
V8
No sir, just a front lever right above the chevy sign.
Old Guy Bill
KY
Bill
Get a “Slim Jim” tool, I’ve used it to get hoods open in the past.
There's not supposed to be a cable. You just move the latch mechanism.
Does the handle not move? Try pushing downward on the hood while you try to release the mechanism. It might be adjusted too tight.
Copymutt
Colorado
If the hood springs are worn you may need to push the hood forward. Easy to do w/ a couple lengths of wood. Try 2x4.
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
When I started my restoration my hood hadn’t been opened since 2008. I was able to get it open a few inches and soaked the hinges in WD-40 and some ATF. After a few hours of gentle wiggling and a few more shots of oil it loosened up enough to start opening regularly.
We converted our '76 back to a '73/74 a few years ago. We have to push down on the hood a bit to get the handle to allow it to pop
Kipps5000
