700r4 speedo port not spinning at all.
randomTruckKid
Rockport tx
It can be either.
Install an electric VSS if you want to go that route, or you can remove the reluctor, install a mechanical drive gear and driven gear, and run a mechanical speedometer.
Well that explains all my troubles and why I was confused on it being meatal.
The electronic vss works better for what I wanted to do.
randomTruckKid
Rockport tx
It can be either.
I can just pop that right in?
PapaBear8486
