Power Steering Pump Fitting Part Number
crooney1189
FL
Carl
Does anyone have the part number for the fitting in the back of the factory power steering pump for an '86? I need to order one, and can't find that fitting listed on RockAuto. My truck didn't have the PS pump anymore when I got it back, and I need to add it to the 5.3 PS pump to reuse the C10 power steering lines.
crooney1189
FL
Carl
Realized I put this post in Tech not Steering, if someone could please move it.
Camar068
10 yrs Air Force
good question for future reference. I'm sure someone will chime in.
Turbo4whl
Downingtown, PA
Wayne
The part you need is a relief valve. Commonly called flow control valve. Early squares have an SAE hose fitting with an inverted seat seal. Later squares like yours, will have a metric "O" ring seal hose.
Amazon has them, but they don't state which one it is. I would think it is the later "O" type since they haven't used the SAE since the 1970's.
Cars that have the same Saginaw pump could have a lower pressure since steering rack needs less pressure than the steering box.
CLICK HERE
Camar068
10 yrs Air Force
Cars that have the same Saginaw pump cold have a lower pressure since steering rack needs less pressure than the steering box.
CLICK HERE
So would the "relief valve" internals need to be changed as well going from an '86 pump to a say 2006 pump? All I changed was the fitting on my swap.
Turbo4whl
Downingtown, PA
Wayne
If the 2006 pump was on a 2 wheel drive 1/2 ton truck with a rack and pinion steering gear, yes. The rack requires less pressure. With a Saginaw steering box on the '06, relief is good.
Devilthe0ry
