dragstews
- Mar 27, 2024
- Belleview Florida US of A
- Jesse
- Body 1954, frame 1975
- R-100
- 406 ci SBC
Wanting the T case shifter to be bout 5 or 6 inches forward of where it was at when the 400 was in it and dead center between the bucket seats ...
There's a small bit of reasoning for the location I'm after..
You see there will be only the T case shifter in the cab ... Won't be a transmission shifter that can be seen .. Having the T case shifter mounted where the trans shift would normally be at is a false trans shifter ...
Sneaky Pete type deal ...
