Vent Window Question
TruckCo
MA
Jay
Good afternoon,
Did a search however could not locate a post. I have an 87 R10 with I believe a 2 piece assembly vent window. I was told as long as you replace the entire assembly, I can put a single gasket assembly in to replace the two piece assembly that isnt as prone to air leaks as bad. I have a junkyard that has a set for cheap that I plan on sending out to PRP. Can anyone confirm that this is true before I go along doing this?
Thank you
ali_c20
Austria
Alexander
C20, K5
TruckCo
MA
Jay
mtbadbob
Montana
Bob
V20
Thats what I plan on doing. Im gonna get the one piece, send it out to PRP and then throw the whole assembly in.
I have a brand-new set of 1 piece seals, I opened the drivers side before I realized that I had the 2 piece versions! Lmk if you want them
TruckCo
MA
Jay
ali_c20
Austria
Alexander
C20, K5
Is the gasket between the actual window and the vent window the same if i switch to a one piece style?
Yes, the vent window assembly frame is the same for all years. Just buy the right door glass run for your year.
As you plan to send the vent window assemblies to PRP give them a call and they will surely provide you all needed parts and information.
Precision has a YouTube channel with tons of installation videos for their products.
https://www.lmctruck.com/1973-87-ch...ts/cc-1973-87-front-door-glass-and-components
Precision YouTube channel
TruckCo
MA
Jay
Ali you said that if i change the assembly to a one piece I need to make sure I get the right glass door run? Isn't the glass door run built into the frame? I looked on their website and its called the "Door Glass Run Channel". Is this what I want? It doesn't mention one piece or two piece on the description. And yes I will be sending them to PRP I wonder if they can just put the right ones on for me. Thanks Ali.
ali_c20
Austria
Alexander
C20, K5
My post was related to the door glass and vent window assembly. The door glass sits in the door glass run and this has different designs 73-80 and 81-87. 73-80 had thick door glass 81 -87 had thin door glass. The 1 or 2 piece design of the vent window glass and seal doesn't matter, The vent window assembly will fit doors from 73-87. PRP will have you covered and everything will work.
sparky77
