- Oct 13, 2016
- Northern Virginia
- Bruce
- K25 Camper Special TH350 NP203
My ‘75 K25 has a TH350 and NP203, and I’ve got stock exhaust manifolds and dual exhaust. Space for the exhaust pipe is ample on the drivers, but really tight on the passenger side because of the shape of the crossmember braces for the NP203. I’ve got a 2 1/4” pipe fit through there, but with not much space around it.
If I switched to headers, are the exhaust pipes usually run under the the T-case crossmember or through it like I have them routed now? It seems that unless the collector is pointed in exactly the right direction to go through the space in the crossmember, routing could be a challenge.
